It is currently Sun Aug 10, 2025 6:49 pm
PostPosted: Thu Feb 15, 2018 9:51 pm
First name: EddieLee
Last Name: Brown
Is there another way to remove or keep finish off the fretboard extension area on the body of the guitar other than taping off that area?
If you tape off the area, What kind of tape do you like and how far from the fretboard edge do you put back?
_____________
EddieLee
PostPosted: Fri Feb 16, 2018 9:36 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
Yes, you can score and route off the lacquer (or use a very sharp chisel). When masking, I use sign maker's tape. It is very thin and low tack. I stay about .050 in from the footprint edge.
It will probably be alright.
PostPosted: Fri Feb 16, 2018 9:43 am
Frisket low tack masking film, matt, set back a little from the outline about 0.75 mm.
It's only 1 thou thick, finish levels over it, but you can still see it, even with silk/matt finishes.
PostPosted: Fri Feb 16, 2018 10:58 am
First name: George
City: Seattle
I use frisket film as well and in the same manner as Colin has described.
George :-)
PostPosted: Fri Feb 16, 2018 1:22 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I use a razor blade as a mini card scraper to remove the finish.
PostPosted: Fri Feb 16, 2018 3:57 pm
I just used blue masking tape and set it around a sixteenth in.
PostPosted: Fri Feb 16, 2018 4:37 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
What I do....
https://howardguitars.blogspot.com/2015/04/spray-finishing-masking-off-surfaces-i.html
Brian
PostPosted: Fri Feb 16, 2018 7:53 pm
Last Name: Sollod
I'm with Haans. Blue masking tape about 1/16" in... Easy-peasy, nothing special...
www.swiftcreekguitars.com
PostPosted: Fri Feb 16, 2018 8:10 pm
Online
Last Name: Colbert
City: Anacortes
My fretboard extensions are bolt-on so no need to mask...
M
